跳转到主内容
Nabi Jr Rear Case Replacement
你所需要的
  1. Nabi Jr Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Rear Case Replacement: 步骤 2 中的图像 1,1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Rear Case Replacement: 步骤 3 中的图像 1,1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Rear Case Replacement: 步骤 4 中的图像 1,1
    • After loosening the back cover, remove it from the device so you can get at the innards.
结论
Tobias Young
于03/24/15注册
27 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 410
