跳转到主内容
Nabi Jr Motherboard Replacement
你所需要的
  1. Nabi Jr Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Motherboard Replacement: 步骤 2 中的图像 1,1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Motherboard Replacement: 步骤 4 中的图像 1,1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
  6. Nabi Jr Motherboard Replacement: 步骤 6 中的图像 1,1
    • De-solder the grey wire from motherboard
  7. Nabi Jr Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use tweezers to peel off all yellow tape from the motherboard
    • Yellow tape is used in all locations where there is ribbon cable present.
  8. Nabi Jr Motherboard Replacement: 步骤 8 中的图像 1,2 Nabi Jr Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
    • Pull black locking tabs up in opposite direction of ribbon cable to remove.
    • Use tweezers to pull the ribbon cable out of the locking tab's slot
  9. Nabi Jr Motherboard Replacement: 步骤 9 中的图像 1,2 Nabi Jr Motherboard Replacement: 步骤 9 中的图像 2,2
    • Lift motherboard to separate it the from the case shell.
结论
Kaila Joy
于03/24/15注册
86 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 1,170
