跳转到主内容
Nabi 2S Speakers Replacement
你所需要的
  1. Nabi 2S Speakers Replacement, Nabi 2S Disassembly: 步骤 1 中的图像 1,1
    • Remove the red rubber case from the device.
  2. Nabi 2S Speakers Replacement: 步骤 2 中的图像 1,2 Nabi 2S Speakers Replacement: 步骤 2 中的图像 2,2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Speakers Replacement: 步骤 3 中的图像 1,1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Speakers Replacement: 步骤 4 中的图像 1,1
    • After the back case is loosened, remove it from the device to change or access the battery.
  5. Nabi 2S Speakers Replacement, Speakers: 步骤 5 中的图像 1,2 Nabi 2S Speakers Replacement, Speakers: 步骤 5 中的图像 2,2
    • Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the 4mm screws in a clockwise rotation.
  6. Nabi 2S Speakers Replacement: 步骤 6 中的图像 1,2 Nabi 2S Speakers Replacement: 步骤 6 中的图像 2,2
    • The speakers are attached to the device via wires that are connected to a circuit. Grasp the circuit connected to the right speaker.
    • Slide the connected wires from the circuit to detach the speakers.
  7. Nabi 2S Speakers Replacement: 步骤 7 中的图像 1,3 Nabi 2S Speakers Replacement: 步骤 7 中的图像 2,3 Nabi 2S Speakers Replacement: 步骤 7 中的图像 3,3
    • Lift the circuit board to get better access for removing the speaker.
    • Grasp the speaker with your fingers and lift it from the plastic
  8. Nabi 2S Speakers Replacement: 步骤 8 中的图像 1,2 Nabi 2S Speakers Replacement: 步骤 8 中的图像 2,2
    • Repeat steps 6 and 7 for the second speaker on the left side.
    • The circuit board should still be loose to remove the speaker.
结论
3等其他人完成本指南。
Riana Ramirez
于03/07/16注册
680 声望
创作了4篇指南
团队
Marist, Team 1-4, Laflen Spring 2016 Marist, Team 1-4, Laflen Spring 2016 的会员
MARS-LAFLEN-S16S1G4
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 6
总计 247
