简介
This guide will aid you in the process of removing the back case of the device. This is useful in replacing a broken back case or to access the battery in the device to replace that as well.
你所需要的
Make sure the screen is facing away from you and the back cover is facing you.
Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
2等其他人完成本指南。
