简介
Warning: This guide requires desoldering/soldering.
This guide will walk you through the steps to removing the Nabi 2 motherboard. A motherboard replacement may be necessary if you experience total device failure. Before beginning this guide we recommend you follow all of the listed prerequisite guides.
Be sure to take extra care when removing the wifi antenna, camera and microphone from the Nabi 2 chassis, before lifting the motherboard out of the device.
你所需要的
Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
Using the soldering iron, detach the speaker's wires from the circuit board.
另外一个人完成了本指南。
