跳转到主内容
Nabi 2 Battery Replacement
你所需要的
  1. Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: 步骤 1 中的图像 1,3 Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: 步骤 1 中的图像 2,3 Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: 步骤 1 中的图像 3,3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Battery Replacement: 步骤 2 中的图像 1,2 Nabi 2 Battery Replacement: 步骤 2 中的图像 2,2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Battery Replacement: 步骤 3 中的图像 1,3 Nabi 2 Battery Replacement: 步骤 3 中的图像 2,3 Nabi 2 Battery Replacement: 步骤 3 中的图像 3,3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Battery Replacement, Battery: 步骤 4 中的图像 1,3 Nabi 2 Battery Replacement, Battery: 步骤 4 中的图像 2,3 Nabi 2 Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Use the spudger to pop the battery out of place and set it aside.
  5. Nabi 2 Battery Replacement: 步骤 5 中的图像 1,3 Nabi 2 Battery Replacement: 步骤 5 中的图像 2,3 Nabi 2 Battery Replacement: 步骤 5 中的图像 3,3
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
结论
4等其他人完成本指南。
Michelle
于02/09/16注册
851 声望
创作了4篇指南
团队
USF Tampa, Team 4-3, Lacy Spring 2016 USF Tampa, Team 4-3, Lacy Spring 2016 的会员
USFT-LACY-S16S4G3
4 名成员
创作了14篇指南
3条评论
Was hoping you could provide the replacement part number for this battery.
ellenanders5 - 回复
It shows on the picture: 1ICP6/68/112
Zoltan -
Hi,
where i can buy this replacement battery?
Thanks
Antanas Stankus - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 9,541
