跳转到主内容
NPET K10V3 Membrane Replacement
你所需要的
  1. NPET K10V3 Membrane Replacement, Key Cap: 步骤 1 中的图像 1,1
    • Remove the keyboard from its power source.
  2. NPET K10V3 Membrane Replacement: 步骤 2 中的图像 1,2 NPET K10V3 Membrane Replacement: 步骤 2 中的图像 2,2
    • Firmly grasp the key that will be removed.
    • Remove the keycap by pulling directly upward.
    • Not pulling straight upward or securely will cause damage to the device.
    • If your fingers cannot get a good grip the key cap, use a key cap puller in the same orientation as with fingers.
  3. NPET K10V3 Membrane Replacement, Membrane: 步骤 3 中的图像 1,1
    • Flip the keyboard over so the bottom is facing upwards.
    • Remove fifteen 4.5 mm screws using a Phillips #2 screwdriver.
    • Remove three 9 mm screws using a Phillips #2 screwdriver.
    • Remove the screws from the kickstand plate first followed by the remaining screws for removal of the backplate.
  4. NPET K10V3 Membrane Replacement: 步骤 4 中的图像 1,2 NPET K10V3 Membrane Replacement: 步骤 4 中的图像 2,2
    • Remove the kickstand.
    • Remove the back plate.
    • Keep in mind the location of the USB cable to ensure it is not damaged when re-assembling.
  5. NPET K10V3 Membrane Replacement: 步骤 5 中的图像 1,2 NPET K10V3 Membrane Replacement: 步骤 5 中的图像 2,2
    • Remove the rubber gasket that compresses the connections.
    • When removing the gasket, lift straight upward to avoid damage and snagging.
    • Clean the gasket if there is any dirt or debris.
    • Do not use chemicals or liquids when cleaning to avoid damage.
  6. NPET K10V3 Membrane Replacement: 步骤 6 中的图像 1,2 NPET K10V3 Membrane Replacement: 步骤 6 中的图像 2,2
    • Remove the membrane gently to reveal the copper connections for both motherboard and membrane.
    • Remove the motherboard from the membrane.
    • Remove the membrane out with the motherboard.
    • When removing both parts, lift straight upward to avoid damage and snagging.
  7. NPET K10V3 Membrane Replacement: 步骤 7 中的图像 1,1
    • Place the membrane with the motherboard on a clean surface.
    • If the membrane is dirty around the key gaskets, clean gently without chemicals or liquids.
结论
另外一个人完成了本指南。
Matthew Costa
于03/18/24注册
343 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-6, Konn Spring 2024 UMass Dartmouth, Team 2-6, Konn Spring 2024 的会员
UMASSD-KONN-S24S2G6
5 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 14
总计 91
