当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
Go around the NABI XD and separate the rear panel from the device.
Battery is glued to the base, lift carefully.
To remove battery, lift the battery up from the motherboard.
Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
Lift the charging port from the NABI XD.
To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
You need to remove 4 ribbons
Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
To disconnect antenna wire, use the tweezers to pry connector straight from the board.
Right (R) speaker removal:
Remove one 4mm Phillips screw.
Use the metal spudger to separate the speaker from the frame.
The speaker is glued to the Nabi XD it will require some force to separate them.
Remove the left (L) speaker wire from the frame by pulling it to the side and up.
The wire in this step, is connected to the charging port. Removing it, is shown in detail on step 6.
Left (L) speaker removal:
Remove two 4mm Phillips screws.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
