跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
NABI XD Motherboard Replacement
你所需要的
  1. NABI XD Motherboard Replacement, Rear panel: 步骤 1 中的图像 1,2 NABI XD Motherboard Replacement, Rear panel: 步骤 1 中的图像 2,2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Motherboard Replacement: 步骤 2 中的图像 1,1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Motherboard Replacement, Battery: 步骤 3 中的图像 1,2 NABI XD Motherboard Replacement, Battery: 步骤 3 中的图像 2,2
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Motherboard Replacement: 步骤 4 中的图像 1,1
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Motherboard Replacement, Charging port: 步骤 5 中的图像 1,2 NABI XD Motherboard Replacement, Charging port: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
  7. NABI XD Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,3 NABI XD Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,3 NABI XD Motherboard Replacement, Motherboard: 步骤 7 中的图像 3,3
    • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
    • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
    • You need to remove 4 ribbons
  8. NABI XD Motherboard Replacement: 步骤 8 中的图像 1,3 NABI XD Motherboard Replacement: 步骤 8 中的图像 2,3 NABI XD Motherboard Replacement: 步骤 8 中的图像 3,3
    • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
    • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
  9. NABI XD Motherboard Replacement: 步骤 9 中的图像 1,2 NABI XD Motherboard Replacement: 步骤 9 中的图像 2,2
    • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
  10. NABI XD Motherboard Replacement: 步骤 10 中的图像 1,2 NABI XD Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
  11. NABI XD Motherboard Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard up away from the Nabi XD.
结论
团队
USF Tampa, Team 17-2, Blackwell Fall 2016 USF Tampa, Team 17-2, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G2
3 名成员
创作了12篇指南
一条评论
Donde puedo conprar la pelicula de la tables o el displey y tatil
maria-201309 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 234
