当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
Go around the NABI XD and separate the rear panel from the device.
Battery is glued to the base, lift carefully.
To remove battery, lift the battery up from the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
