跳转到主内容
简介
Has the battery been damaged or the device won't charge. Changing the battery may fix these problems.
配件
没有特定配件。
  1. Use the plastic opening tool at the top left corner seam, then pry the corner apart. Use the plastic opening tool at the top left corner seam, then pry the corner apart.
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. Place your fingernails on both sides of the connector and pull it straight back away from the holder. Place your fingernails on both sides of the connector and pull it straight back away from the holder.
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. Battery is glued to the base, lift carefully.
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
结论
Marissa Schiereck
于2016年09月15日注册
638 信誉积分
创作了6篇指南
团队
USF Tampa, Team 17-2, Blackwell Fall 2016 USF Tampa, Team 17-2, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G2
3 名成员
创作了12篇指南
一条评论
Where can you get the battery?
Dave - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 661
