跳转到主内容
Changing SSD disk why! N131WU
你所需要的
  1. Changing SSD disk why! N131WU, Remove the Screws: 步骤 1 中的图像 1,1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. Changing SSD disk why! N131WU, Remove the Keyboard: 步骤 2 中的图像 1,3 Changing SSD disk why! N131WU, Remove the Keyboard: 步骤 2 中的图像 2,3 Changing SSD disk why! N131WU, Remove the Keyboard: 步骤 2 中的图像 3,3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. Changing SSD disk why! N131WU, Remove Keyboard Connections: 步骤 3 中的图像 1,3 Changing SSD disk why! N131WU, Remove Keyboard Connections: 步骤 3 中的图像 2,3 Changing SSD disk why! N131WU, Remove Keyboard Connections: 步骤 3 中的图像 3,3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. Changing SSD disk why! N131WU, Remove the upper screws: 步骤 4 中的图像 1,2 Changing SSD disk why! N131WU, Remove the upper screws: 步骤 4 中的图像 2,2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. Changing SSD disk why! N131WU, Remove the SSD: 步骤 5 中的图像 1,3 Changing SSD disk why! N131WU, Remove the SSD: 步骤 5 中的图像 2,3 Changing SSD disk why! N131WU, Remove the SSD: 步骤 5 中的图像 3,3
    • Remove the screw holding in the ssd.
    • Carefully remove the SSD from the connector.
结论
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
30,884 声望
创作了264篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 501
