跳转到主内容
N-Strike Nite Finder EX-3 Battery Replacement
你所需要的
  1. N-Strike Nite Finder EX-3 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • The batteries are located in the handle of the blaster.
    • The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
  2. N-Strike Nite Finder EX-3 Battery Replacement: 步骤 2 中的图像 1,1
    • Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
    • If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
结论
团队
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G8
3 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 2,620
