跳转到主内容
加入维修社区 - 创建账户
MyArcade Micro Player Broken Joystick/D-Pad Replacement
你所需要的
  1. MyArcade Micro Player Broken Joystick/D-Pad Replacement, Joystick/D-Pad: 步骤 1 中的图像 1,3 MyArcade Micro Player Broken Joystick/D-Pad Replacement, Joystick/D-Pad: 步骤 1 中的图像 2,3 MyArcade Micro Player Broken Joystick/D-Pad Replacement, Joystick/D-Pad: 步骤 1 中的图像 3,3
    • Flip the cabinet over and remove the four 10 mm-long Phillips #2 screws from the back casing of the cabinet.
    • Use a hairdryer to lightly heat the stickers on the side of the cabin.
    • Peel back the sticker far enough to reveal the screws.
    • Remove the three 5 mm-long Phillips screws underneath the stickers of each side of the cabinet.
    询问修复机器人
    添加评论
  2. MyArcade Micro Player Broken Joystick/D-Pad Replacement: 步骤 2 中的图像 1,1
    • Carefully pry the back of the cabinet open of the cabinet with your hands.
    • If a sticker on top prevents you from prying it open, remove it to access the cabinet.
    询问修复机器人
    添加评论
  3. MyArcade Micro Player Broken Joystick/D-Pad Replacement: 步骤 3 中的图像 1,1
    • Remove the three 10 mm-long Phillips #1 screws holding the motherboard in place.
    • Carefully pry it away to get to the barrier.
    • Do NOT apply too much pressure when removing. The screen can get punctured/damaged.
    询问修复机器人
    添加评论
  4. MyArcade Micro Player Broken Joystick/D-Pad Replacement: 步骤 4 中的图像 1,3 MyArcade Micro Player Broken Joystick/D-Pad Replacement: 步骤 4 中的图像 2,3 MyArcade Micro Player Broken Joystick/D-Pad Replacement: 步骤 4 中的图像 3,3
    • Use the hair dryer to heat the sticker in front. Peel it off slowly to give ease when it comes to removing the barrier.
    • On the edges of the barrier, remove the four 8 mm-long Phillips #1 screws.
    询问修复机器人
    添加评论
  5. MyArcade Micro Player Broken Joystick/D-Pad Replacement: 步骤 5 中的图像 1,2 MyArcade Micro Player Broken Joystick/D-Pad Replacement: 步骤 5 中的图像 2,2
    • Push the controller container out of the cabinet.
    • Remove the five 7 mm-long Phillips #1 screws located underneath.
    询问修复机器人
    添加评论
  6. MyArcade Micro Player Broken Joystick/D-Pad Replacement: 步骤 6 中的图像 1,1
    • Take off the joystick from the panel, and locate the silicone padding.
    • Remove the damaged one and replace it with your new one.
    询问修复机器人
    添加评论
结论
After the last step, follow the process backwards to reassemble the cabinet back in proper condition.
Once done, Congrats! With careful time and proper handling, your cabinet is good to go again! Have fun playing, and thank you for listening and preventing E-Waste.
取消:我没有完成这个指南。
Emilio Vargas
于09/24/25注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 25
过去 30 天: 136
总计 936
