跳转到主内容
Munchkinz Volume Button assembly
你所需要的
  1. Munchkinz Volume Button assembly, Opening Device: 步骤 1 中的图像 1,1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Volume Button assembly, Pry Device Apart: 步骤 2 中的图像 1,2 Munchkinz Volume Button assembly, Pry Device Apart: 步骤 2 中的图像 2,2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Volume Button assembly, Separated Device: 步骤 3 中的图像 1,1
    • After prying the device apart, it should look like this.
  4. Munchkinz Volume Button assembly, Pry Camera: 步骤 4 中的图像 1,1
    • Use the slim plastic opening tool to pry the camera from its initial position.
  5. Munchkinz Volume Button assembly, Disconnect Ribbon: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
  6. Munchkinz Volume Button assembly, Volume Button: 步骤 6 中的图像 1,1
    • Remove the plastic volume button.
  7. Munchkinz Volume Button assembly, Unscrew Module: 步骤 7 中的图像 1,1
    • Remove the two screws that hold the volume button assembly in place.
  8. Munchkinz Volume Button assembly, Solder Module Wires: 步骤 8 中的图像 1,1
    • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
结论
David Wood
于02/05/15注册
440 声望
创作了4篇指南
团队
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 的会员
UWT-ROSE-W15S3G6
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 288
