跳转到主内容
Munchkinz LCD Assembly
你所需要的
  1. Munchkinz LCD Assembly, Opening Device: 步骤 1 中的图像 1,1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz LCD Assembly, Pry Device Apart: 步骤 2 中的图像 1,2 Munchkinz LCD Assembly, Pry Device Apart: 步骤 2 中的图像 2,2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz LCD Assembly, Separated Device: 步骤 3 中的图像 1,1
    • After prying the device apart, it should look like this.
  4. Munchkinz LCD Assembly, Remove Speaker: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to remove the speaker from the casing.
  5. Munchkinz LCD Assembly, Pry Camera: 步骤 5 中的图像 1,1
    • Use the slim plastic opening tool to pry the camera from its position.
  6. Munchkinz LCD Assembly, Unscrew Volume Module: 步骤 6 中的图像 1,2 Munchkinz LCD Assembly, Unscrew Volume Module: 步骤 6 中的图像 2,2
    • Unscrew the two screws that hold the volume module to the casing.
  7. Munchkinz LCD Assembly, Pry Battery: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  8. Munchkinz LCD Assembly, Remove Ribbons: 步骤 8 中的图像 1,1
    • Remove the two highlighted ribbons from the motherboard.
  9. Munchkinz LCD Assembly, Remove Screws: 步骤 9 中的图像 1,1
    • Use the screw driver to remove the highlighted screws.
  10. Munchkinz LCD Assembly, Remove Hidden Screw: 步骤 10 中的图像 1,1
    • Use the plastic opening tool to hold the camera ribbon back.
    • Unscrew the screw under ribbon with the screw driver.
  11. Munchkinz LCD Assembly, Remove Motherboard: 步骤 11 中的图像 1,1
    • Remove the motherboard from the casing.
  12. Munchkinz LCD Assembly, Pry Up Screen: 步骤 12 中的图像 1,3 Munchkinz LCD Assembly, Pry Up Screen: 步骤 12 中的图像 2,3 Munchkinz LCD Assembly, Pry Up Screen: 步骤 12 中的图像 3,3
    • Oriented the device so the battery is closest to the user.
    • Use the plastic opening tool to pry the clips up to release LCD screen.
    • Gently lift the northern end of the screen and slide it out horizontally.
  13. Munchkinz LCD Assembly, Solder LCD Wires: 步骤 13 中的图像 1,1
    • Unsolder the black and red LCD wires.
结论
另外一个人完成了本指南。
David Wood
于02/05/15注册
440 声望
创作了4篇指南
团队
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 的会员
UWT-ROSE-W15S3G6
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 436
