跳转到主内容
Munchkinz External Casing Removal
你所需要的
  1. Munchkinz External Casing Removal, Opening Device: 步骤 1 中的图像 1,1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz External Casing Removal, Pry Device Apart: 步骤 2 中的图像 1,2 Munchkinz External Casing Removal, Pry Device Apart: 步骤 2 中的图像 2,2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz External Casing Removal, Separated Device: 步骤 3 中的图像 1,1
    • After prying the device apart, it should look like this.
结论
Austin Oliveira
于02/05/15注册
204 声望
创作了2篇指南
团队
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 的会员
UWT-ROSE-W15S3G6
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 159
