跳转到主内容
Munchkinz Battery Replacement
你所需要的
  1. Munchkinz Battery Replacement, Opening Device: 步骤 1 中的图像 1,1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Battery Replacement, Pry Device Apart: 步骤 2 中的图像 1,2 Munchkinz Battery Replacement, Pry Device Apart: 步骤 2 中的图像 2,2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Battery Replacement, Separated Device: 步骤 3 中的图像 1,1
    • After prying the device apart, it should look like this.
  4. Munchkinz Battery Replacement, Removing battery: 步骤 4 中的图像 1,3 Munchkinz Battery Replacement, Removing battery: 步骤 4 中的图像 2,3 Munchkinz Battery Replacement, Removing battery: 步骤 4 中的图像 3,3
    • Use the wide plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  5. Munchkinz Battery Replacement, Remove battery completely: 步骤 5 中的图像 1,1
    • Use the Soldering Iron to disconnect the each cable.
结论
Hee Jin Cho
于01/14/15注册
113 声望
撰写一个指南
团队
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 的会员
UWT-ROSE-W15S3G6
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 519
