跳转到主内容
Munchkin Mozart Magic Cube Sound Button Replacement
你所需要的
  1. Munchkin Mozart Magic Cube Sound Button Replacement, Face plate: 步骤 1 中的图像 1,2 Munchkin Mozart Magic Cube Sound Button Replacement, Face plate: 步骤 1 中的图像 2,2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Sound Button Replacement: 步骤 2 中的图像 1,1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Sound Button Replacement: 步骤 3 中的图像 1,1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Sound Button Replacement: 步骤 4 中的图像 1,1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Sound Button Replacement: 步骤 5 中的图像 1,1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Sound Button Replacement: 步骤 6 中的图像 1,1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Sound Button Replacement: 步骤 7 中的图像 1,1
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube Sound Button Replacement, Sound Button: 步骤 8 中的图像 1,1
    • Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up using the Jimmy to remove the glue connecting the motherboard to the white frame.
  9. Munchkin Mozart Magic Cube Sound Button Replacement: 步骤 9 中的图像 1,1
    • Slide the motherboard out of the frame.
  10. Munchkin Mozart Magic Cube Sound Button Replacement: 步骤 10 中的图像 1,2 Munchkin Mozart Magic Cube Sound Button Replacement: 步骤 10 中的图像 2,2
    • To remove the button use your fingers or forceps to remove the gray rubber button piece on the green side of the motherboard.
结论
团队
USF Tampa, Team 1-4, Sullivan Fall 2015 USF Tampa, Team 1-4, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S1G4
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 621
