跳转到主内容
Munchkin Mozart Magic Cube Face plate Replacement
你所需要的
  1. Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: 步骤 1 中的图像 1,2 Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: 步骤 1 中的图像 2,2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Face plate  Replacement: 步骤 2 中的图像 1,1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Face plate  Replacement: 步骤 3 中的图像 1,1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Face plate  Replacement: 步骤 4 中的图像 1,1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Face plate  Replacement: 步骤 5 中的图像 1,1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Face plate  Replacement: 步骤 6 中的图像 1,1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Face plate  Replacement: 步骤 7 中的图像 1,1
    • Remove the rubber corners by simply pulling them off.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 1-4, Sullivan Fall 2015 USF Tampa, Team 1-4, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S1G4
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,156
