跳转到主内容
Multipoint Door Lock Lock 'gearbox' Replacement
你所需要的
  1. Multipoint Door Lock  Lock 'gearbox' Replacement, Problem with front door lock: 步骤 1 中的图像 1,1
    • This door and it's lock is probably abou 22 years old. It's the type where you have to lift the handle to engage the 3 point locking mechanism. Recently this lifting started to get more difficult sometimes sticking and requiring several attempts to make work.
    • Note: The removal/replacement process may have to be done twice. First time to identify the problem and the make/model to order.
    • Subsequent to doing this I came across these youtube video guides for uPVC door lock replacement which it would be useful to view before doing this. https://www.youtube.com/watch?v=usEivKYL... https://www.youtube.com/watch?v=nEDbRB27...
  2. Multipoint Door Lock  Lock 'gearbox' Replacement, Remove door edge cover: 步骤 2 中的图像 1,1
    • Remove door edge cover. Keep the screws somewhere safe in the order they are fitted so you know where to put them back.
    • Sorry about photos, getting a clear edge on photo isn't easy.
  3. Multipoint Door Lock  Lock 'gearbox' Replacement, Remove multipoint mechanism: 步骤 3 中的图像 1,1
    • Remove the retaining screws from the moving part of the locking mechanism again making sure you know where they came from. There were only 2 on mine.
    • Take care as the parts become loose as the top and bottom catches are only held in place by the cover , you may want help here. Remove and place out of the way.
  4. Multipoint Door Lock  Lock 'gearbox' Replacement, Remove cylinder lock: 步骤 4 中的图像 1,2 Multipoint Door Lock  Lock 'gearbox' Replacement, Remove cylinder lock: 步骤 4 中的图像 2,2
    • Remove handle retaining screws and then carefully take handles off from both side taking care not to lose the operating shaft and any other parts.
    • Remove cylinder lock retaining screw and then remove lock making a note of which end is outside.
  5. Multipoint Door Lock  Lock 'gearbox' Replacement, Remove gearbox: 步骤 5 中的图像 1,2 Multipoint Door Lock  Lock 'gearbox' Replacement, Remove gearbox: 步骤 5 中的图像 2,2
    • Gearbox can now be removed. First time around this may simply to be to identify the problem and/or identify the make/model for replacement.
    • In this particular case there was cracking around the 'barrel' that takes the handle shaft which was causing the sticking.
    • To identify the make/model required for replacement I spent ages on Google. You need several key measurements and by studying various lock supplier websites I found it was almost the same as an older model Fullex type A.
    • Close study of the pictures on the websites seemed to show that the very top and bottom mounting points may be slighter thicker than mine. But I thought it to be a low risk as the door is wood cored I could chisel a bit out if neccessary.
  6. Multipoint Door Lock  Lock 'gearbox' Replacement, New gearbox: 步骤 6 中的图像 1,1
    • When the new gearbox arrived there were a couple of plastic inserts that had to be removed. Don't forget to do that before installing (unlike me!).
    • Also note the latch came fitted the wrong way round but was easily rotated using it's screw.
    • A quick bit of chiselling allowed the new gearbox to fit.
    • As a precaution I greased what I thought would be key points of wear.
    • All that is left is reassembly by reversing the steps taken.
结论
Clive Ousbey
于04/05/20注册
133 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 52
过去 30 天: 98
总计 4,645
