跳转到主内容
Mt. Fury Roadmaster Tire Replacement
你所需要的
  1. Mt. Fury Roadmaster Tire Replacement, Inner Tube: 步骤 1 中的图像 1,1
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Mt. Fury Roadmaster Tire Replacement: 步骤 2 中的图像 1,1
    • Using a 15mm wrech, loosen the axial nut.
  3. Mt. Fury Roadmaster Tire Replacement: 步骤 3 中的图像 1,2 Mt. Fury Roadmaster Tire Replacement: 步骤 3 中的图像 2,2
    • Pull the chain slack and remove the tire.
  4. Mt. Fury Roadmaster Tire Replacement: 步骤 4 中的图像 1,2 Mt. Fury Roadmaster Tire Replacement: 步骤 4 中的图像 2,2
    • Insert the flat side of the tire lever between the inside edge of the rim and the seal of the tire.
    • Clip the tire lever to the nearest spoke.
  5. Mt. Fury Roadmaster Tire Replacement: 步骤 5 中的图像 1,2 Mt. Fury Roadmaster Tire Replacement: 步骤 5 中的图像 2,2
    • Insert the second tire lever next to first and slowly slide it along the outside edge of the rim until one side of the tire is off the rim.
  6. Mt. Fury Roadmaster Tire Replacement: 步骤 6 中的图像 1,1
    • Re-insert the first tire lever to hook the opposite seam of the tire and repeat steps 3 through 5.
  7. Mt. Fury Roadmaster Tire Replacement: 步骤 7 中的图像 1,1
    • Remove the cap from the inner tube, and pull the valve stem out of the rim.
结论
To install new inner tube, follow these instructions in reverse order.
4等其他人完成本指南。
团队
Cal Poly, Team 1-40, Maness Winter 2014 Cal Poly, Team 1-40, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G40
4 名成员
创作了5篇指南
一条评论
Replace also means how to put it back together!
ellik - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 46
总计 6,813
