跳转到主内容
Mt. Fury Roadmaster Rear Derailleur Replacement
你所需要的
  1. Mt. Fury Roadmaster Rear Derailleur Replacement, Rear Derailleur: 步骤 1 中的图像 1,1
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 2 中的图像 1,2 Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 2 中的图像 2,2
    • Locate and remove the main axle nuts (both sides) with a 15mm open-end wrench.
  3. Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 3 中的图像 1,2 Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 3 中的图像 2,2
    • Pull the chain slack and remove the tire.
  4. Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 4 中的图像 1,1
    • Locate and remove the rear phillips head screw on the sprocket to remove one side of chain guard.
  5. Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 5 中的图像 1,2 Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 5 中的图像 2,2
    • Rotate the derailleur arm forward to access the phillips head screw from the forwardmost sprocket. Remove the screw.
    • Be careful to hold the chain guard in place so the sprocket and washers don't fall out. (Chain guard is highlighted in red).
  6. Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 6 中的图像 1,1
    • Locate and loosen the hex bolt that clamps the shifting cable.
  7. Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 7 中的图像 1,1
    • Remove mounting screw that attaches the derailleur to the bicycle frame.
  8. Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 8 中的图像 1,2 Mt. Fury Roadmaster Rear Derailleur Replacement: 步骤 8 中的图像 2,2
    • Loosen the shifting cable tension adjustment nut and remove the cable from the derailleur assembly .
结论
To install new derailleur, follow these instructions in reverse order.
6等其他人完成本指南。
Monty Dodge Jr
于01/22/14注册
669 声望
创作了2篇指南
团队
Cal Poly, Team 1-40, Maness Winter 2014 Cal Poly, Team 1-40, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G40
4 名成员
创作了5篇指南
2条评论
Directions are simple clear and to the point. Excellent!
Paul J. Baker - 回复
Now how do you put it back?
Wendy Navarro - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 8,045
