跳转到主内容
Mt. Fury Roadmaster Brake Pad Replacement
你所需要的
  1. Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: 步骤 1 中的图像 1,2 Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: 步骤 1 中的图像 2,2
    • Locate and remove the dome nut with a 10mm open-end wrench.
  2. Mt. Fury Roadmaster Brake Pad Replacement: 步骤 2 中的图像 1,1
    • Inspect brake pad for wear.
  3. Mt. Fury Roadmaster Brake Pad Replacement: 步骤 3 中的图像 1,1
    • Dome nut (left), lock washer (middle), and brake pad (right).
    • Be sure to save the dome nut and lock washer just in case the replacement brake shoe does not include them.
    • When installing the new brake shoe, make sure it is properly aligned so it is in full contact with the edge of the rim.
结论
To install your new brake shoes, follow these instructions in reverse order.
另外一个人完成了本指南。
Monty Dodge Jr
于01/22/14注册
669 声望
创作了2篇指南
团队
Cal Poly, Team 1-40, Maness Winter 2014 Cal Poly, Team 1-40, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G40
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 2,069
