跳转到主内容
简介
Replacing the power cord on the TF6 requires several wiring tools and previous experience with soldering. For soldering tips and directions, consult the guide on how to solder and desolder connections.
  1. Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  3. Gently lift the bottom cover, detaching it from the main body of the TF6.
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
  4. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  5. Using a Phillips #1 screwdriver, remove the two 13mm Phillips screws that are securing the wire harness.
    • Using a Phillips #1 screwdriver, remove the two 13mm Phillips screws that are securing the wire harness.
  6. Carefully lift the wire harness from the base of the TF6, detaching it completely.
    • Carefully lift the wire harness from the base of the TF6, detaching it completely.
    • The power cord wiring is now completely accessible.
  7. Using a set of wire cutters, cut both leads of the power cord at the heatshrinked area where the leads split. Using a set of wire cutters, cut both leads of the power cord at the heatshrinked area where the leads split.
    • Using a set of wire cutters, cut both leads of the power cord at the heatshrinked area where the leads split.
  8. Using your fingers, pry the heatshrink off from the power cord leads. Using your fingers, pry the heatshrink off from the power cord leads.
    • Using your fingers, pry the heatshrink off from the power cord leads.
  9. Using a 14-16 AWG wire stripper, strip the leads on the replacement power cord.
    • Using a 14-16 AWG wire stripper, strip the leads on the replacement power cord.
  10. Solder the power cord's positive lead to the white nylon wire.
    • Solder the power cord's positive lead to the white nylon wire.
    • Solder the power cord's ground lead to the bronze nylon wire.
    • Ensure the correct leads are being soldered together (power to power, ground to ground). Soldering the incorrect leads together will result in hazardous conditions for both the TF6 and the user when the unit is powered on.
    • Consult the replacement power cord's user manual, packaging, or manufacturer in order to verify the power and ground leads.
结论
Andrew
于2014年01月24日注册
101 信誉积分
撰写一个指南
团队
Cal Poly, Team 13-18, Regan Winter 2014 Cal Poly, Team 13-18, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G18
4 名成员
创作了5篇指南
Good tutorial, I like this
Sfapa - 回复
Excellent! very helpful...
NP Designs 123 - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 603
