跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
The bottom cover must be removed prior to replacing or repairing any internal parts of the Mr. Coffee TF6 (hot plate, power cord, and water tubes). In the event that the bottom cover breaks or must be replaced, a replacement cover must by obtained from the manufacturer.
配件
没有特定配件。
  1. Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  3. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  4. Gently lift the bottom cover, detaching it from the main body of the TF6.
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
结论
Johnny Romeka
于2014年01月24日注册
201 信誉积分
创作了2篇指南
团队
Cal Poly, Team 13-18, Regan Winter 2014 Cal Poly, Team 13-18, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G18
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 390
