跳转到主内容
Mr. Coffee DW13 Tubing Replacement
你所需要的
  1. Mr. Coffee DW13 Tubing Replacement, Base: 步骤 1 中的图像 1,2 Mr. Coffee DW13 Tubing Replacement, Base: 步骤 1 中的图像 2,2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Tubing Replacement: 步骤 2 中的图像 1,2 Mr. Coffee DW13 Tubing Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Tubing Replacement: 步骤 3 中的图像 1,1
    • Gently lift the base cover to expose the inside of the coffee machine.
    SO interesting! I love fixing things, myself. Many things are so
    easy, if looked at logically, and/or long enough.
    Nice site!
    I don't have a clue how I came here to it.
    haskinskristin43 - 回复
    Anyone know the Mr. Coffee part number for the white tubing? My Mr. Coffee maker model #BVMC-EVX23. Ty.
    Pam - 回复
  4. Mr. Coffee DW13 Tubing Replacement, Tubing: 步骤 4 中的图像 1,2 Mr. Coffee DW13 Tubing Replacement, Tubing: 步骤 4 中的图像 2,2
    • Identify and remove the two 13mm screws securing the silver support bracket using a phillips head screw driver.
  5. Mr. Coffee DW13 Tubing Replacement: 步骤 5 中的图像 1,1
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
  6. Mr. Coffee DW13 Tubing Replacement: 步骤 6 中的图像 1,2 Mr. Coffee DW13 Tubing Replacement: 步骤 6 中的图像 2,2
    • Use pliers to pinch and loosen the crimps.
  7. Mr. Coffee DW13 Tubing Replacement: 步骤 7 中的图像 1,1
    • Once the crimps are loosened, slide them down the tubing.
  8. Mr. Coffee DW13 Tubing Replacement: 步骤 8 中的图像 1,2 Mr. Coffee DW13 Tubing Replacement: 步骤 8 中的图像 2,2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
  9. Mr. Coffee DW13 Tubing Replacement: 步骤 9 中的图像 1,3 Mr. Coffee DW13 Tubing Replacement: 步骤 9 中的图像 2,3 Mr. Coffee DW13 Tubing Replacement: 步骤 9 中的图像 3,3
    • Gently pull on plastic tubing, freeing it from the coffee maker
    • One of the tubes has a red ball check valve in the middle. Be sure to note which hole it connects to.
结论
3等其他人完成本指南。
Kinsie Ward
于01/26/14注册
213 声望
撰写一个指南
团队
Cal Poly, Team 10-31, Maness Winter 2014 Cal Poly, Team 10-31, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G31
4 名成员
创作了6篇指南
8条评论
Great photos. I've done this on another mr coffee model twice. Once for lime buildup, once for a coffee ground clogging it. Make sure you are gentle with the soft tubing. I split the hose at one end. The clamps now barely covers the split, but I'm looking for a replacement tube and ball valve.
markvassmer - 回复
I did not have to detach the heating coil from the plate in order to remove the tubing.
I found that the check valve was clogged with debris on my unit. Blowing it out cleared the clog. My unit's check valve is built into the tube that goes from the reservoir to the coil, so I only had to remove that tube to solve my issue.
rulegit2000 - 回复
Where does the tube with the check valve attach?
latimert36@windstream.net
Thomas Latimer -
Water inlet tube from the tank on my model Mr. Coffee BVMC-SJX33GT.
Mark Vassmer -
MarkVassmer -- did you find a replacement tube and ball valve? If so, where?
jay_amor - 回复
No. Still looking for tube/check valve as I had again today had to disassemble and clean the inlet tube from the reservoir and the split seems longer. I wonder if it would still work efficiently with a new tube without a check valve?
Mark Vassmer -
Amazon: HOS9X13 . You must transfer a valve from one of the water feed tubes and insert into the replacement hose, note the position. It has to be cut out of the old hose. This prevents backflow and the hose from collapsing from a vacuum so its generally close to the water source.
How much life you get from the repair depends on how corroded the aluminum tube is or if you are willing to live with bottom drips. While there are deposits that can be wiped out , the tube corrosion needs smooth refinishing to prevent leaks of steam which then condense on the bottom and drip out. Once you notice the dripping, the spring clips can also be rusted out, and not as tight as they used to be. The newer basic Mr Coffee similar to the above unit is at Amazon now for $15 overnight as prime, and the hose is $5, add spring clips if needed.
I G - 回复
where can i order this part? Mr Coffee Dw13 tubing replacement
Robert - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 38
总计 7,221
