跳转到主内容
Mr. Coffee DW13 Power Cord Replacement
你所需要的
  1. Mr. Coffee DW13 Power Cord Replacement, Base: 步骤 1 中的图像 1,2 Mr. Coffee DW13 Power Cord Replacement, Base: 步骤 1 中的图像 2,2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Power Cord Replacement: 步骤 2 中的图像 1,2 Mr. Coffee DW13 Power Cord Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Power Cord Replacement: 步骤 3 中的图像 1,1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 Power Cord Replacement, Power Cord: 步骤 4 中的图像 1,2 Mr. Coffee DW13 Power Cord Replacement, Power Cord: 步骤 4 中的图像 2,2
    • Locate the white tab that covers and holds the power cord in place. It has two screws on either side of it.
    • Use a #2 Philips Head screwdriver to unscrew the two 13mm screws holding the tab in place.
  5. Mr. Coffee DW13 Power Cord Replacement: 步骤 5 中的图像 1,2 Mr. Coffee DW13 Power Cord Replacement: 步骤 5 中的图像 2,2
    • Gently lift up on the white tab, removing it from the coffee machine.
  6. Mr. Coffee DW13 Power Cord Replacement: 步骤 6 中的图像 1,2 Mr. Coffee DW13 Power Cord Replacement: 步骤 6 中的图像 2,2
    • Locate the 2 electrical connectors running from the black plastic-coated power cord to the interior of the power switch.
    • One cord is copper colored and ends at the power switch in a silver metal square.
    • The other cord is white and ends at the power switch in a black plastic square.
  7. Mr. Coffee DW13 Power Cord Replacement: 步骤 7 中的图像 1,2 Mr. Coffee DW13 Power Cord Replacement: 步骤 7 中的图像 2,2
    • Grasp the copper cord close to the power switch. Lightly pull the silver end tab from the end to detach it.
  8. Mr. Coffee DW13 Power Cord Replacement: 步骤 8 中的图像 1,2 Mr. Coffee DW13 Power Cord Replacement: 步骤 8 中的图像 2,2
    • Lightly pull the white cord away from the power switch by grasping the black plastic-coated head.
    • There are two white cords attached to each other. Pull them apart by grasping the different black heads and separating them.
  9. Mr. Coffee DW13 Power Cord Replacement: 步骤 9 中的图像 1,3 Mr. Coffee DW13 Power Cord Replacement: 步骤 9 中的图像 2,3 Mr. Coffee DW13 Power Cord Replacement: 步骤 9 中的图像 3,3
    • Pull the power cord through the hole at the back of the base of the machine, followed by the two colored cords.
结论
3等其他人完成本指南。
Tess Bradley
于01/26/14注册
373 声望
创作了3篇指南
团队
Cal Poly, Team 10-31, Maness Winter 2014 Cal Poly, Team 10-31, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G31
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 11
过去 30 天: 21
总计 3,167
