简介
To complete this repair you will need pilers, a Philips head screwdriver, and a flathead screw driver. During this repair you will remove the base of the coffee machine, loosen the support bar, before finally removing the heating plate and prying out the O-ring.
你所需要的
Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
在这个步骤中使用的工具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm Flathead Screwdriver to pry out the O-ring.
3等其他人完成本指南。
