跳转到主内容
Mr. Coffee DW13 O Ring Replacement
你所需要的
  1. Mr. Coffee DW13 O Ring Replacement, Base: 步骤 1 中的图像 1,2 Mr. Coffee DW13 O Ring Replacement, Base: 步骤 1 中的图像 2,2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 O Ring Replacement: 步骤 2 中的图像 1,2 Mr. Coffee DW13 O Ring Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 O Ring Replacement: 步骤 3 中的图像 1,1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 O Ring Replacement, O Ring: 步骤 4 中的图像 1,2 Mr. Coffee DW13 O Ring Replacement, O Ring: 步骤 4 中的图像 2,2
    • Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
  5. Mr. Coffee DW13 O Ring Replacement: 步骤 5 中的图像 1,1
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
  6. Mr. Coffee DW13 O Ring Replacement: 步骤 6 中的图像 1,2 Mr. Coffee DW13 O Ring Replacement: 步骤 6 中的图像 2,2
    • Use needle-nose pilers to pinch and loosen the crimps
  7. Mr. Coffee DW13 O Ring Replacement: 步骤 7 中的图像 1,1
    • Once the crimps are loosened, slide them down the tubing.
  8. Mr. Coffee DW13 O Ring Replacement: 步骤 8 中的图像 1,2 Mr. Coffee DW13 O Ring Replacement: 步骤 8 中的图像 2,2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
  9. Mr. Coffee DW13 O Ring Replacement: 步骤 9 中的图像 1,2 Mr. Coffee DW13 O Ring Replacement: 步骤 9 中的图像 2,2
    • Place one of your hands on the front side of the heating plate.
    • Use this hand to gently push the heating plate towards yourself and out of the machine.
  10. Mr. Coffee DW13 O Ring Replacement: 步骤 10 中的图像 1,2 Mr. Coffee DW13 O Ring Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    购买
结论
3等其他人完成本指南。
团队
Cal Poly, Team 10-31, Maness Winter 2014 Cal Poly, Team 10-31, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G31
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,018
