跳转到主内容
Mr. Coffee DRX5 Water Reservoir Replacement
你所需要的
  1. Mr. Coffee DRX5 Water Reservoir Replacement, Water Reservoir: 步骤 1 中的图像 1,3 Mr. Coffee DRX5 Water Reservoir Replacement, Water Reservoir: 步骤 1 中的图像 2,3 Mr. Coffee DRX5 Water Reservoir Replacement, Water Reservoir: 步骤 1 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
  2. Mr. Coffee DRX5 Water Reservoir Replacement: 步骤 2 中的图像 1,3 Mr. Coffee DRX5 Water Reservoir Replacement: 步骤 2 中的图像 2,3 Mr. Coffee DRX5 Water Reservoir Replacement: 步骤 2 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
  3. Mr. Coffee DRX5 Water Reservoir Replacement: 步骤 3 中的图像 1,2 Mr. Coffee DRX5 Water Reservoir Replacement: 步骤 3 中的图像 2,2
    • Remove 2 hose clamps from heating element. Remove heating element from tubes.
  4. Mr. Coffee DRX5 Water Reservoir Replacement: 步骤 4 中的图像 1,3 Mr. Coffee DRX5 Water Reservoir Replacement: 步骤 4 中的图像 2,3 Mr. Coffee DRX5 Water Reservoir Replacement: 步骤 4 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove one 10mm screw, and three 11mm screws connecting the reservoir to the base and remove reservoir from the base.
结论
Michael Chhim
于03/21/17注册
202 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 591
