跳转到主内容
Mr. Coffee DRX5 Warming Plate Replacement
你所需要的
  1. Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: 步骤 1 中的图像 1,3 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: 步骤 1 中的图像 2,3 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: 步骤 1 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
  2. Mr. Coffee DRX5 Warming Plate Replacement: 步骤 2 中的图像 1,1
    • Slide display out of the way.
  3. Mr. Coffee DRX5 Warming Plate Replacement: 步骤 3 中的图像 1,3 Mr. Coffee DRX5 Warming Plate Replacement: 步骤 3 中的图像 2,3 Mr. Coffee DRX5 Warming Plate Replacement: 步骤 3 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
  4. Mr. Coffee DRX5 Warming Plate Replacement: 步骤 4 中的图像 1,1
    • Pull heating element out of the way.
  5. Mr. Coffee DRX5 Warming Plate Replacement: 步骤 5 中的图像 1,1
    • Twist warming plate clockwise so that the tab is out of place. Remove warming plate.
结论
Michael Chhim
于03/21/17注册
202 声望
创作了2篇指南
团队
一条评论
Interesting that you can take the thing apart, do nothing else but put it back together again, and it’s supposed to be fixed? What about the step of replacing the broken part? I don’t see mention of that.
destravlr - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 569
