跳转到主内容
加入维修社区 - 创建账户
Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement
你所需要的
  1. Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement, Base: 步骤 1 中的图像 1,1
    • Turn your coffee maker over so that the base is facing up.
    询问修复机器人
    添加评论
  2. Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 2 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 2 中的图像 2,2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
    询问修复机器人
    添加评论
  3. Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement, security screws: 步骤 3 中的图像 1,1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
    询问修复机器人
    添加评论
  4. Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 4 中的图像 1,1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
    询问修复机器人
    添加评论
  5. Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement, Rubber Hose: 步骤 5 中的图像 1,3 Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement, Rubber Hose: 步骤 5 中的图像 2,3 Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement, Rubber Hose: 步骤 5 中的图像 3,3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
    添加评论
  6. Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 6 中的图像 1,3 Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 6 中的图像 2,3 Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 6 中的图像 3,3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
    询问修复机器人
    添加评论
  7. Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 7 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 7 中的图像 2,2
    • Slide metal clamps off hoses.
    询问修复机器人
    添加评论
  8. Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 8 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 8 中的图像 2,2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
    询问修复机器人
    添加评论
  9. Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 9 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Rubber Hose Replacement: 步骤 9 中的图像 2,2
    • Grip the hoses and pull them straight up and out.
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
San Diego State, Team 1-4, Sheppard Winter 2015 San Diego State, Team 1-4, Sheppard Winter 2015 的会员
SDSU-SHEPPARD-W15S1G4
2 名成员
创作了12篇指南
4指南评论
how can I buy this part
wmfitzsr1 - 回复 分享
That is indeed the question. Because of planned obsolescence companies basically assume you will just buy an entirely new coffee maker. My best suggestion is to buy a similar model at a thrift store like Goodwill and use the parts from that.
Mackenzie Aiken - 回复 分享
I noticed red hose - and transparent hose - when one uses one or other - not all are FDA approved as food grade hoses ?
I thought transparent is often food grade FDA marked - and it can be marked high temp up to 500 degrees
But never the red - the red is high temp but it may not be food grade - Question:" How to verify when one has the hose that it is from a seller ?
~~~~~ Two Questions Below: ~~~~~~~~~~~
How is best way to verify hose as drinking water safe ?
What diameter hose should one get for Model : BVMC-SJX33GT [ Mr Coffee Maker ] ? Metric/English -size for it is ?
richard.depaulo - 回复 分享
Amazon: HOS9X13 . You must transfer a valve from one of the water feed tubes and insert into the replacement hose, note the position. It has to be cut out of the old hose. This prevents backflow and the hose from collapsing from a vacuum so its generally close to the water source.
How much life you get from the repair depends on how corroded the aluminum tube is. While there are deposits that can be wiped out , bad metal corrosion needs refinishing to be smooth and prevent the smallest leaks of steam even with a new hose. New tighter spring clamps will help. So even if a major leak is stopped, a steam leak will make the bottom damp.
I G - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 74
总计 8,029
