跳转到主内容
加入维修社区 - 创建账户
Mr. Coffee BVMC-SJX33GT O-Rings Replacement
你所需要的
  1. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Base: 步骤 1 中的图像 1,1
    • Turn your coffee maker over so that the base is facing up.
    询问修复机器人
    添加评论
  2. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 2 中的图像 1,2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 2 中的图像 2,2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
    询问修复机器人
    添加评论
  3. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, security screws: 步骤 3 中的图像 1,1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
    询问修复机器人
    添加评论
  4. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 4 中的图像 1,1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
    询问修复机器人
    添加评论
  5. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: 步骤 5 中的图像 1,3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: 步骤 5 中的图像 2,3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: 步骤 5 中的图像 3,3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
    添加评论
  6. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 6 中的图像 1,3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 6 中的图像 2,3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 6 中的图像 3,3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
    询问修复机器人
    添加评论
  7. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 7 中的图像 1,2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 7 中的图像 2,2
    • Slide metal clamps off hoses.
    询问修复机器人
    添加评论
  8. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 8 中的图像 1,2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 8 中的图像 2,2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
    询问修复机器人
    添加评论
  9. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 9 中的图像 1,2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 9 中的图像 2,2
    • Grip the hoses and pull them straight up and out.
    添加评论
  10. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: 步骤 10 中的图像 1,3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: 步骤 10 中的图像 2,3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: 步骤 10 中的图像 3,3
    • Locate the two 17mm screws securing the bracing bar.
    • Unscrew the screws with a #2 Phillip's head screwdriver and remove the bracing bar
    添加评论
  11. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 11 中的图像 1,2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 11 中的图像 2,2
    • Using a finger to keep the heating plate in place, grip the metal tubing and gently pull it away from the plate.
    • Set the metal tubing aside.
    询问修复机器人
    添加评论
  12. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 12 中的图像 1,2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 12 中的图像 2,2
    • Push the heating plate up from below and remove.
    添加评论
  13. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, O-Rings: 步骤 13 中的图像 1,2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, O-Rings: 步骤 13 中的图像 2,2
    • Locate the five 11.5mm screws securing the plastic ring to the coffee maker.
    • Unscrew the screws using a #2 Phillip's head screwdriver.
    询问修复机器人
    添加评论
  14. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 14 中的图像 1,3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 14 中的图像 2,3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 14 中的图像 3,3
    • Using a plastic opening tool, pry the first o-ring out of the plastic ring.
    • If you happen to mix up the o-rings, note that this o-ring is thicker than the second.
    询问修复机器人
    添加评论
  15. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 15 中的图像 1,2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 15 中的图像 2,2
    • Gripping the plastic ring, pull it free from the coffee maker.
    • Flip the plastic ring over.
    询问修复机器人
    添加评论
  16. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 16 中的图像 1,2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 步骤 16 中的图像 2,2
    • Using your fingers, pry the other o-ring free from the plastic ring.
    • If you happen to mix up the o-rings, note that this o-ring is thinner than the first.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
San Diego State, Team 1-4, Sheppard Winter 2015 San Diego State, Team 1-4, Sheppard Winter 2015 的会员
SDSU-SHEPPARD-W15S1G4
2 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 46
总计 2,797
