跳转到主内容
加入维修社区 - 创建账户
Mr. Coffee BVMC-SJX33GT Heating Plate Replacement
你所需要的
  1. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Base: 步骤 1 中的图像 1,1
    • Turn your coffee maker over so that the base is facing up.
    询问修复机器人
    添加评论
  2. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 2 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 2 中的图像 2,2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
    询问修复机器人
    添加评论
  3. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, security screws: 步骤 3 中的图像 1,1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
    询问修复机器人
    添加评论
  4. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 4 中的图像 1,1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
    询问修复机器人
    添加评论
  5. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Rubber Hose: 步骤 5 中的图像 1,3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Rubber Hose: 步骤 5 中的图像 2,3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Rubber Hose: 步骤 5 中的图像 3,3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
    添加评论
  6. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 6 中的图像 1,3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 6 中的图像 2,3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 6 中的图像 3,3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
    询问修复机器人
    添加评论
  7. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 7 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 7 中的图像 2,2
    • Slide metal clamps off hoses.
    询问修复机器人
    添加评论
  8. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 8 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 8 中的图像 2,2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
    询问修复机器人
    添加评论
  9. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 9 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 9 中的图像 2,2
    • Grip the hoses and pull them straight up and out.
    添加评论
  10. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Heating Plate: 步骤 10 中的图像 1,3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Heating Plate: 步骤 10 中的图像 2,3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Heating Plate: 步骤 10 中的图像 3,3
    • Locate the two 17mm screws securing the bracing bar.
    • Unscrew the screws with a #2 Phillip's head screwdriver and remove the bracing bar
    添加评论
  11. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 11 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 11 中的图像 2,2
    • Using a finger to keep the heating plate in place, grip the metal tubing and gently pull it away from the plate.
    • Set the metal tubing aside.
    询问修复机器人
    添加评论
  12. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 12 中的图像 1,2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: 步骤 12 中的图像 2,2
    • Push the heating plate up from below and remove.
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
San Diego State, Team 1-4, Sheppard Winter 2015 San Diego State, Team 1-4, Sheppard Winter 2015 的会员
SDSU-SHEPPARD-W15S1G4
2 名成员
创作了12篇指南
7指南评论
I need to know which of the various high-heat thermal paste should be used that will maintain re-bonding the heating tube to the heating plate. The manufacturer did not use thermal grease as it appears it will not maintain the bond between the heating tube and the heating element. They instead used a vertically stable paste that assumes a hardened consistency of chalk to best maintain the bond in the presence of water. However, I have yet to find the proper paste which bonds while tolerating the sufficient intermittent high heat ratings required. The manufacturer has been unable to provide any assistance or information. Can you please tell me what material to use in this circumstance. Thanks KB.
K B - 回复 分享
I am unfortunately unaware of the answer to this question. I hope someone else can answer it.
Mackenzie Aiken - 回复 分享
The two inline thermal fuses (brass cylinders with a black end) are far more likely to fail than the heating element. Check them first.
T99 or Super Lube
3 oz. Tube Heat Sink Compound
can be used with the heater.
gdrgry34fsdf324 - 回复 分享
Where can I obtain the heating plate? The coating has burned off and now rust corrosion has to scrubbed off after every use (including off the glass pot!!). Thanks.
B Welkinator - 回复 分享
Liked to video. Thanks for posting. Where can I purchase the black metal heating plate for Oster coffee maker or any maker?
Stephanie Gross - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 28
过去 30 天: 131
总计 7,701
