跳转到主内容
Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement
你所需要的
  1. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement, Hose Replacement: 步骤 1 中的图像 1,1
    • Unplug the coffee maker.
    • Empty the coffee maker reservoir.
  2. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 2 中的图像 1,2 Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 2 中的图像 2,2
    • Flip the coffee maker upside down.
    • Remove the six 13.5 mm screws from the bottom of the coffee maker using a Phillips #3 screwdriver.
  3. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 3 中的图像 1,1
    • Remove the base using an opening tool.
  4. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 4 中的图像 1,2 Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 4 中的图像 2,2
    • Pinch the metal ties with a pair of needle-nose pliers.
    • Slide the metal tie off the metal tube base.
  5. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 5 中的图像 1,3 Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 5 中的图像 2,3 Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to push against the plastic tubing and slide it off the metal tube base.
  6. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 6 中的图像 1,1
    • Using a pair of needle-nose pliers, pinch the metal ties together and slide the metal tie up off of the base.
  7. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 7 中的图像 1,1
    • To remove the tube, pinch the tubing and pull until it pops off.
  8. Mr. Coffee 12-Cup Coffee Maker BVMC-EHXX33 Hose Replacement: 步骤 8 中的图像 1,1
    • Remove any debris from the base. If the filter is corroded, remove the filter by squeezing the filter and move it up the base of the tube until it comes out.
结论
JoMax Christensen
于11/19/21注册
165 声望
撰写一个指南
一条评论
nice pictures, what is the size and material of the tube?
Dean Taeger - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 36
总计 497
