跳转到主内容
加入维修社区 - 创建账户
Mpow MPBH063 Battery Replacement
你所需要的
    1. Mpow MPBH063 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Mpow MPBH063 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Mpow MPBH063 Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
      • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
      询问修复机器人
      添加评论
    2. Mpow MPBH063 Battery Replacement: 步骤 2 中的图像 1,1
      在这个步骤中使用的工具:
      • Remove four JIS J00 12mm screws.
      • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
      询问修复机器人
      添加评论
    3. Mpow MPBH063 Battery Replacement: 步骤 3 中的图像 1,1
      • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
      • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
      • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
      询问修复机器人
      添加评论
    4. Mpow MPBH063 Battery Replacement: 步骤 4 中的图像 1,1
      • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
      询问修复机器人
      添加评论
结论
To insert a new replacement battery and reassemble your device, follow these instructions in reverse order.
取消:我没有完成这个指南。
Lianna Cook
于10/09/18注册
272 声望
创作了2篇指南
团队
2指南评论
Where can I find a replacement battery for this speaker?
Sean DuBois - 回复 分享
I’ve owned this speaker for ages and have never been able to use it to charge anything. Can someone tell me what sequence of button I have to press to get it to work as a power bank?
RJ En - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 28
总计 4,802
