跳转到主内容
Mpow 059 Ear Cushion Replacement
你所需要的
  1. Mpow 059 Ear Cushion Replacement, Ear Cushion: 步骤 1 中的图像 1,2 Mpow 059 Ear Cushion Replacement, Ear Cushion: 步骤 1 中的图像 2,2
    • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
    • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
    • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
    • Applying too much pressure can damage ear cushion.
  2. Mpow 059 Ear Cushion Replacement: 步骤 2 中的图像 1,1
    • Remove the ear cushion away from the speaker to completely detach it from the headphones.
结论
7等其他人完成本指南。
Danielle Furtado
于03/25/22注册
490 声望
创作了2篇指南
团队
UMass Dartmouth, Team E-1, Gurgel Spring 2022 UMass Dartmouth, Team E-1, Gurgel Spring 2022 的会员
UMASSD-GURGEL-S22SEG1
3 名成员
创作了4篇指南
8条评论
thank you. very helpfule.
P Gill - 回复
These instructions do not mention anything about the fact that you need a new adhesive to make the new earpads stay. Now I won't have headphones until I'm able to purchase an adhesive.
Cody Owens - 回复
Is there a recommendation on the replacement ear pads?
Some say glue is needed but does this depend on the replacement pads?
ms13sp - 回复
Works great. I have replaced my earpads 3 times with no glue. I use these MOKOS earpads from amazon. Replacement earpads for Mpow 059
Thanks for the step by step guide. I love these Mpow headphones, mostly for the controls on the right ear.
anotherdee - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 143
总计 6,425
