跳转到主内容
加入维修社区 - 创建账户
Mounting and dismounting the tablet
你所需要的
  1. Mounting and dismounting the tablet, Mounting and dismounting the tablet: 步骤 1 中的图像 1,1
    • The hull seen from the front.
    添加评论
  2. Mounting and dismounting the tablet: 步骤 2 中的图像 1,1
    • The case seen from the back, with the jacks where to connect your handsets
    询问修复机器人
    添加评论
  3. Mounting and dismounting the tablet: 步骤 3 中的图像 1,1
    • Enough to redo a shell in case of problems, but without the feet.
    • The T14 snake-eyes tip to disassemble the facade.
    • Collars to block the jacks of your handsets under the shell.
    • Replacement snake eyes M6 screws, M6 inserts to remake a shell
    询问修复机器人
    添加评论
  4. Mounting and dismounting the tablet: 步骤 4 中的图像 1,1
    • Use the tip to disassemble the screws.
    • DO IT MANUALLY!!!
    • Not to the screwdriver, because it will rip. And the tip will damage the facade.
    询问修复机器人
    添加评论
  5. Mounting and dismounting the tablet: 步骤 5 中的图像 1,1
    • To block the jacks of the handsets: make a knot on the collar.
    • Thus, users will not be able to disconnect the handsets
    询问修复机器人
    添加评论
  6. Mounting and dismounting the tablet: 步骤 6 中的图像 1,1
    • If you want to redo a shell:
    • You have to cut the inserts, and pierce the bottom to pass the usb plug and the jack that connects to the tablet.
    • Take the model delivered as an example
    询问修复机器人
    添加评论
  7. Mounting and dismounting the tablet: 步骤 7 中的图像 1,1
    • To change the content of the micro SD card:
    • You must disassemble the facade, remove the tablet from the shell and open the "SD card" hatch
    • Create a file named: sexbreizh.avi
    • AVI container, mp3 audio codec, xvid video codec
    • Audio bitrate: 44100
    • Video rate: 8000
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
AFPD Conception
于04/01/14注册
244 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 19
过去 30 天: 117
总计 2,699
