跳转到主内容
Mountain Bike Brake Lever Replacement
你所需要的
  1. Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: 步骤 1 中的图像 1,2 Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: 步骤 1 中的图像 2,2
    • Remove the grip from the handle.
    • Do this by twisting and pulling the grip until it slides off.
  2. Mountain Bike Brake Lever Replacement: 步骤 2 中的图像 1,2 Mountain Bike Brake Lever Replacement: 步骤 2 中的图像 2,2
    • Using a 5mm allen key, loosen the lever assembly from the handle.
    • Slide the assembly off of the handle.
  3. Mountain Bike Brake Lever Replacement: 步骤 3 中的图像 1,1
    • Take your new lever assembly and slide it onto the handle; leave it loose.
  4. Mountain Bike Brake Lever Replacement: 步骤 4 中的图像 1,2 Mountain Bike Brake Lever Replacement: 步骤 4 中的图像 2,2
    • Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
  5. Mountain Bike Brake Lever Replacement: 步骤 5 中的图像 1,1
    • Line up your lever assembly back into place.
    • Tighten the screw with the allen key to secure it.
  6. Mountain Bike Brake Lever Replacement: 步骤 6 中的图像 1,3 Mountain Bike Brake Lever Replacement: 步骤 6 中的图像 2,3 Mountain Bike Brake Lever Replacement: 步骤 6 中的图像 3,3
    • Install the brake cable into the lever housing.
    • Take the brake cable and feed it into the lever pull.
  7. Mountain Bike Brake Lever Replacement: 步骤 7 中的图像 1,3 Mountain Bike Brake Lever Replacement: 步骤 7 中的图像 2,3 Mountain Bike Brake Lever Replacement: 步骤 7 中的图像 3,3
    • Feed the cable into the lever assembly slot and through the barrel adjuster.
    • Use the barrel adjuster to tighten the cable intro place.
结论
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 122
总计 3,735
