跳转到主内容
Moultrie I45 GameSpy Casing Replacement
你所需要的
  1. Moultrie I45 GameSpy Casing Replacement, Casing: 步骤 1 中的图像 1,1
    • Using a Philips head screwdriver, remove the eight 6mm screws located at the bottom of the device.
  2. Moultrie I45 GameSpy Casing Replacement: 步骤 2 中的图像 1,1
    • Remove the butterfly nut from the lid arm.
  3. Moultrie I45 GameSpy Casing Replacement: 步骤 3 中的图像 1,1
    • Remove the lid-covering.
  4. Moultrie I45 GameSpy Casing Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips head screwdriver, remove the six 4mm screws from the face of the camera.
  5. Moultrie I45 GameSpy Casing Replacement: 步骤 5 中的图像 1,1
    • Gently separate the two halves of the case.
    • The two halves are connected by a wire. Pulling too roughly can damage the wires and cause the camera to stop functioning.
结论
Sean Hill
于01/29/15注册
485 声望
创作了4篇指南
团队
UW Tacoma, Team 3-7, Rose Winter 2015 UW Tacoma, Team 3-7, Rose Winter 2015 的会员
UWT-ROSE-W15S3G7
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 236
