跳转到主内容
修复你的物品
维修的权力
商店
简介
Once the back cover has been removed, the microphone can be accessed as shown in this guide.
配件
没有特定配件。
  1. Slide the cover release button towards the bottom of the phone Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Push the battery towards the top of the phone and lift up.
    • Push the battery towards the top of the phone and lift up.
  3. With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  4. Lift the circuit board away from the case of the phone, being careful not to break the wire that goes up into the hinge. This will give you access to the microphone. The microphone sits just below the keys on the front cover molding. Grasp the microphone with tweezers and lift it out of the front cover.
    • Lift the circuit board away from the case of the phone, being careful not to break the wire that goes up into the hinge. This will give you access to the microphone.
    • The microphone sits just below the keys on the front cover molding.
    • Grasp the microphone with tweezers and lift it out of the front cover.
结论
Carson Meena
于2012年10月22日注册
16 信誉积分
创作了5篇指南
团队
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G2
4 名成员
创作了17篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 238
