当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Slide the cover release button towards the bottom of the phone
Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
The four screws holding the upper half of the phone together should now be visible.
With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
The LCD screen should now be completely separated from the phone.
Use a spudger to detach the ribbon cable connecting the the LCD Screen to the rest of the phone.
The LCD Scren will now lift out from the phone casing.
Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
