跳转到主内容
Motorola i710 LCD Screen Cover Replacement
你所需要的
  1. Motorola i710 LCD Screen Cover Replacement, Battery Cover: 步骤 1 中的图像 1,2 Motorola i710 LCD Screen Cover Replacement, Battery Cover: 步骤 1 中的图像 2,2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 LCD Screen Cover Replacement, Battery: 步骤 2 中的图像 1,1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: 步骤 3 中的图像 1,3 Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: 步骤 3 中的图像 2,3 Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: 步骤 3 中的图像 3,3
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
  4. Motorola i710 LCD Screen Cover Replacement: 步骤 4 中的图像 1,2 Motorola i710 LCD Screen Cover Replacement: 步骤 4 中的图像 2,2
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
  5. Motorola i710 LCD Screen Cover Replacement: 步骤 5 中的图像 1,3 Motorola i710 LCD Screen Cover Replacement: 步骤 5 中的图像 2,3 Motorola i710 LCD Screen Cover Replacement: 步骤 5 中的图像 3,3
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
结论
Carson Meena
于10/22/12注册
16 声望
创作了5篇指南
团队
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G2
4 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 387
