跳转到主内容
Motorola i710 Keypad Sensor Replacement
  1. Motorola i710 Keypad Sensor Replacement, Battery Cover: 步骤 1 中的图像 1,2 Motorola i710 Keypad Sensor Replacement, Battery Cover: 步骤 1 中的图像 2,2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Keypad Sensor Replacement, Battery: 步骤 2 中的图像 1,1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Keypad Sensor Replacement, Motherboard: 步骤 3 中的图像 1,3 Motorola i710 Keypad Sensor Replacement, Motherboard: 步骤 3 中的图像 2,3 Motorola i710 Keypad Sensor Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
  4. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: 步骤 4 中的图像 1,2 Motorola i710 Keypad Sensor Replacement, Keypad Sensor: 步骤 4 中的图像 2,2
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
结论
Katelyn
于10/22/12注册
1 声望
创作了2篇指南
团队
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G2
4 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 317
