跳转到主内容
修复你的物品
维修的权力
商店
简介
Once the back casing has been removed, the charger cover will be accessible for replacement.
配件
没有特定配件。
  1. Slide the cover release button towards the bottom of the phone Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Push the battery towards the top of the phone and lift up.
    • Push the battery towards the top of the phone and lift up.
  3. With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  4. Once you have taken off the back cover of the phone, the charger tab can be lifted out of position on the back cover.
    • Once you have taken off the back cover of the phone, the charger tab can be lifted out of position on the back cover.
结论
Caitlin Smith
于2012年10月22日注册
4 信誉积分
创作了2篇指南
团队
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 的会员
CLEM-BENSON-F12S14G2
4 名成员
创作了17篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 328
