跳转到主内容
Motorola i560 Motherboard Replacement
你所需要的
  1. Motorola i560 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Pull the antenna up to reveal two of the six screws.
  4. Motorola i560 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unscrew all six screws on the back side of the phone using a T-6 bit.
  5. Motorola i560 Motherboard Replacement: 步骤 5 中的图像 1,2 Motorola i560 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Gently separate the front and back sides of the phone, as shown in the picture.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Motherboard Replacement: 步骤 6 中的图像 1,2 Motorola i560 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Detach the first ribbon cable by unplugging it from the motherboard.
  7. Motorola i560 Motherboard Replacement: 步骤 7 中的图像 1,2 Motorola i560 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Detach the speaker ribbon cable from the motherboard.
  8. Motorola i560 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
结论
另外一个人完成了本指南。
Ariel
于03/11/13注册
19 声望
创作了4篇指南
团队
Clemson, Team 13-6, Benson Spring 2013 Clemson, Team 13-6, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 152
