跳转到主内容
Motorola i560 Microphone Replacement
你所需要的
  1. Motorola i560 Microphone Replacement, Battery: 步骤 1 中的图像 1,1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Microphone Replacement: 步骤 2 中的图像 1,1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Microphone Replacement, Side Volume Button: 步骤 3 中的图像 1,1
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. Motorola i560 Microphone Replacement: 步骤 4 中的图像 1,1
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  5. Motorola i560 Microphone Replacement: 步骤 5 中的图像 1,2 Motorola i560 Microphone Replacement: 步骤 5 中的图像 2,2
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Microphone Replacement: 步骤 6 中的图像 1,2 Motorola i560 Microphone Replacement: 步骤 6 中的图像 2,2
    • Detach the first ribbon cable by unplugging it from the logic board.
  7. Motorola i560 Microphone Replacement: 步骤 7 中的图像 1,3 Motorola i560 Microphone Replacement: 步骤 7 中的图像 2,3 Motorola i560 Microphone Replacement: 步骤 7 中的图像 3,3
    • Gently remove the side button by pulling the buttons away from the phone.
  8. Motorola i560 Microphone Replacement, Metal Support Plate: 步骤 8 中的图像 1,3 Motorola i560 Microphone Replacement, Metal Support Plate: 步骤 8 中的图像 2,3 Motorola i560 Microphone Replacement, Metal Support Plate: 步骤 8 中的图像 3,3
    • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
  9. Motorola i560 Microphone Replacement, Microphone: 步骤 9 中的图像 1,3 Motorola i560 Microphone Replacement, Microphone: 步骤 9 中的图像 2,3 Motorola i560 Microphone Replacement, Microphone: 步骤 9 中的图像 3,3
    • Slightly bend the phone frame to expose microphone protrusion.
    • Gently remove microphone using your fingers.
  10. Motorola i560 Microphone Replacement: 步骤 10 中的图像 1,1
    • Once the microphone has been removed, remove the connecting piece
结论
Haley S
于03/11/13注册
10 声望
创作了4篇指南
团队
Clemson, Team 13-6, Benson Spring 2013 Clemson, Team 13-6, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 149
