当前版本的文档还未经巡查,您可以查看最新的已查核版本。
拆解
这个拆解是不是维修指南。 要维修你的的Motorola i450 Boost Mobile,请使用我们的维修手册。
这个步骤还没有翻译 帮忙翻译一下
Place the phone on a flat surface with the front facing down and the antenna fully extended.
Use a spudger to remove the circular rubber cover from the base of the antenna.
Remove the 3.2 mm Torx T5 screw located under the rubber cover.
Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone.
Do not grasp the black antenna piece to pull it out. Doing so may damage it.
Place the phone on a flat surface with the front facing down.
Insert your finger under the gray plastic cover at the bottom end of the phone.
Lift the cover off the phone.
Place your thumb in the notch in the lower left corner of the battery compartment.
Lift the battery up and away from the phone.
Remove the battery.
Locate the metal slider that holds the SIM card in place.
Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
Lift the metal flap to gain access to the bottom of the SIM card.
Remove the SIM card by sliding it out parallel to the bottom of the flap.
Extend the antenna.
Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
If the antenna is not fully extended, the top left screw will not be accessible.
Gently lift off the back half of the phone and set to the side.
Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
Gently lift the end of the circuit board farthest from the phone hinge.
The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
Grasp the keypad at the bottom of the phone, raise it, and pull it away.
Exploded view of all phone components.
与5其他贡献者
于10/22/12注册
3 声望
撰写一个指南
徽章: 6
+ 3更多徽章
CLEM-BENSON-F12S15G2
4 名成员
创作了16篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 14
总计 1,256
