跳转到主内容
Motorola i450 Boost Mobile SIM Card Replacement
你所需要的
  1. Motorola i450 Boost Mobile SIM Card Replacement, Back Cover: 步骤 1 中的图像 1,3 Motorola i450 Boost Mobile SIM Card Replacement, Back Cover: 步骤 1 中的图像 2,3 Motorola i450 Boost Mobile SIM Card Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile SIM Card Replacement, Battery: 步骤 2 中的图像 1,3 Motorola i450 Boost Mobile SIM Card Replacement, Battery: 步骤 2 中的图像 2,3 Motorola i450 Boost Mobile SIM Card Replacement, Battery: 步骤 2 中的图像 3,3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile SIM Card Replacement, SIM Card: 步骤 3 中的图像 1,2 Motorola i450 Boost Mobile SIM Card Replacement, SIM Card: 步骤 3 中的图像 2,2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile SIM Card Replacement: 步骤 4 中的图像 1,3 Motorola i450 Boost Mobile SIM Card Replacement: 步骤 4 中的图像 2,3 Motorola i450 Boost Mobile SIM Card Replacement: 步骤 4 中的图像 3,3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
结论
Garrison Stevens
于10/22/12注册
1 声望
创作了6篇指南
团队
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 的会员
CLEM-BENSON-F12S15G2
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 687
